Brake Caliper / Lines
capps
I have a 1984 GMC Suburban K2500 4X4. I purchased replacement brake lines and calipers from two different sources. When I purchased the calipers, there were 6 or 7 different brake codes like. JB7, JD7, JB6, JD6, JB5, JD5. After doing a little research it looks like it may be a JB6 or JD6 brake system. I no longer have the codes in the glove box.
The replacement brake lines have this end and I believe it also fit on the caliper I removed as a core
The line I took off has this end on it
I am not sure which to swap out. Do I have the wrong caliper or lines? I did not notice the issue until I went to put it back together.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,082 Guests (See full list)
