Window Sticker-Can I get one?
Quailtail
I just bought a 2005 Silverado with 7500 miles. I am trying to see what options were included when the truck was purchased by the original owner.
How can I get a copy?
Unless they're a dealer-installed item (like bug shields and nerf bars), all of your factory equipment should be listed on the RPO sticker on the inside of the glovebox.
Pm MS3DALE and he can get you a gm sheet on your vehicle showing installed components and all work performed by a GM dealer, includes all info from a GM dealer. including any recall info and warranty status.Put your email in your pm and he can send it to you by email.
Brian
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
