96 Yukon headlights
clarkoh
Greetings,
I have a 96 Yukon and my headlights died last week. I have no Daytime Running Lights or low beams. Dash lights and high beams are just fine.
I was thinking it was probably the headlight switch, but since the DRL should run with the switch off, the switch didn't seem like such a good fix. Any thoughts?
Thanks!
Possible DRL module or DRL relay.  Just a wild ass guess since you basically have no diagnostics information to go on.
Thank you for your reply. I have looked over the other posts which might cover my problem, but they seem to deal with either headlights not working or DRL not working. My problem is no DRL and no low beams.
I have only checked for voltage at the headlight itself (checked for volts between the 2 wires, and each wire to ground) and found no volts.
I am just not sure which other components: DRL module, DRL relay, or DRL diode might affect the low beams in addition to the DRL. I was going to pull the DRL diode and do a diode check with my digital meter, but was not sure if that was a good test for this component, or if the diode would affect the low beams.
Any help would be greatly appreciated!
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 273 Guests (See full list)
