6.0 water pump replacement
wgabert
I have a antifreeze leak from the left side of the engine (01-2500-hd-6.0L) and it appears I may have a water pump gasket problem. The weep hole is dry. Would anyone have a tech article written for water pump replacement.
This is for the 4.8L, 5.3L, & 6.0L .
Remove or disconnect the following:
Air inlet duct
Coolant
Inlet radiator hose from the water pump
Upper fan shroud
Cooling fan and clutch assembly
Drive belt
Radiator outlet hose from the coolant pump
Surge tank hose
Heater hose
Water pump
To install:
NOTE: DO NOT use cooling system seal tabs (or similar compounds) unless otherwise instructed. The use of cooling system seal tabs (or similar compounds) may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
Install or connect the following:
Water pump. Install the water pump bolts. Tighten the water pump bolts first pass to 15 Nm (11 ft. lbs.); tighten the bolts final pass to 30 Nm (22 ft. lbs.).
Water pump drive belt pulley and bolts (if applicable). Tighten the pulley bolts first pass to 10 Nm (89 inch lbs.); tighten the bolts final pass to 25 Nm (18 ft. lbs.).
Surge tank hose
Heater hose
Outlet radiator hose to the coolant pump
Drive belt
Upper fan shroud
Inlet radiator hose to the water pump
Air inlet duct
Coolant
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 842 Guests (See full list)
