Help with VIN problem
warmstrong
I had an earlier thread on here about my 2004 Chevy Suburban's Autoride not functioning properly. This was a big selling point for me due to towing a bass boat frequently. I took it into the service dept and they tell me it doesnt have Autoride. The salesman and sales manager just have a confused look on their face and dont seem to know whats going on, which is making me really nervous. They say theyll have to do some research to see exactly whats on there. Im hoping you guys can help me with this. The VIN is 1GNFK16Z64J269319. Id like to know whats really on this thing. Its supposed to have AWD and some other options, but im getting suspicious about maybe not getting what I thought I was getting. Any help would be greatly appreciated.
That won't be contained in your VIN. It will be listed in the RPO codes that are on a sticker inside your glove box.
Under "Resources" on the left of the page here, there is an RPO code guide that should help you out.
And as far as I know, there is no such beast as "AWD" on Suburbans. Just 2WD or 4WD.
The owners manual talks about it and has a pic of the buttons and they match mine. I dont understand how it works, or if thats exactly whats on mine. Also, I used the RPO code stuff and there was quite a few codes that are in my glove box that arent listed there. Is there any other way to tell whats really on this thing without listing all those RPO codes?
Some of the RPO codes on the label aren't worth knowing the meaning of like if the truck was ordered for dealer stock or for a customer or even if there was an order acknowledgment sent.
Someone in the Service Department can print out the vehicle build sheet for you and it'll have all of this information. When I've asked for it in the past, they have always given me one. (I try to ask nice and pick a time when it looks like they aren't busy with other important things.)
Someone here on the Forums has even e-mailed all of this information for my truck. (If I could only remember who.)
I see "Automatic Level Control" and "Electronic Suspension Control" listed in the service manual. I think the problem is that the terms they use are different between the sales people and the service manual. Nowhere do I see Autoride except in the Owners Manual. By comparing the descriptions of everything, it looks like "G69 Level Control Auto, Air, HD" and "Electronic Suspension Control" together with "Automatic Level Control" and "Autoride" all mean the same thing.
Here's everything for a 2004 Chevrolet 4WD Suburban in the factory service manual...
AC6 Window Tinted Deep, Rear, S/D
AE7 Seat FRT Split, Driver, PASS
AG1 Adjuster FRT ST Power, Multi-Directional, Driver
AG2 Adjuster PASS ST Power, Multi-Directional
AJ1 Windows Deep Tint, All Except W/S And DRS
AJ7 Restraint System Seat, Inflatable, Driver and Passenger, Front and Side
AL0 Sensor Indicator Inflatable Restraint, Front Passenger/Child Presence Detector
AL4 Seat RR BKT
ANJ Window Tinted Export Compliant, Non-Deep
AN3 Seat FRT, Individual (Non BKT)
AP9 Net Convenience
ARL Plant Code Arlington, TX USA
AS3 Seat RR
AT5 Seat Rear CTR, Folding
AU0 Remote Function Actuation - Keyless Entry - Domestic
AU3 Lock Control Side Door, Electric
AU8 Remote Function Actuation, Specific Frequency
AX4 Restraint Conversion Seat, Manual, European
A04 Windshield Tinted, Less Upper Shadeband
A31 Window Power Operated, All Doors
A95 Seat FRT BKT, High Back, Driver and PASS RECL
BAG Parts Package Export
BG9 Rubber Floor Covering
BPH Appearance Package Chevrolet Off Road
BS1 Insulation Acoustical PKG
BVE Side Steps Runningboard
BVF Side Steps Runningboard, Color Keyed
BVQ Side Steps Runningboard, Tubular Chrome
BVR Side Steps Runningboard, Tubular Stainless Steel
BVS Side Steps Runningboard, Color
BW1 Ornamentation Exterior Rear End
BW2 Molding B/S Deluxe
BX2 Molding B/S Lower, Extra Wide
B30 Floor Covering Carpet
B37 Covering Floor Mat, Front and Rear, Auxiliary
B39 Covering Floor Carpet, Load Floor
B41 Covering Floor Mat, Load Floor
B58 Covering Floor MAT, FRT And RR, Carpeted Insert
B71 Wheel Opening Flares
B85 Molding - Body Side , Exterior, Bright
B96 Molding Wheel Opening
CF5 Roof Sun Glass, Sliding, Electric
CJ2 HVAC System Air Conditioner Front, Auto Temperature Control, Auxiliary Temperature Control
CJ3 HVAC System Air Conditioner Front, Manual Temperature Control, Auxiliary Temperature Control
C25 Wiper System, Rear Window, Intermittent
C36 Heater Auxiliary
C49 Defogger RR Window, Electric
C5H GVW Rating 6,900 LBS
C5U GVW Rating 6,800 LBS
C5W GVW Rating 7,000 LBS
C5Z GVW Rating 7,200 LBS
C6P GVW Rating 8,600 LBS/3,900 KG
C69 HVAC System Rear Air Conditioner
C7K GVW Rating 6,500 lbs
DF5 Mirror, I/S R/V LT Sensitive, Compass, O/S Temp Display
DH6 Mirror, I/S Front Van, LH And RH, Illumination with Sunshade
DK7 Console Roof Interior, Custom
DK8 Console Roof Interior, Deluxe
DL3 Mirror, O/S LH and RH, Remote Control, Electric, Heated, Power Folding, Turn Signal Indicator, Light Sensitive, Color
DL8 Mirror, O/S LH And RH, Remote Control, Electric, Heated
DNR Equipment, Dealer Installed
DPF Mirror, O/S LH and RH, Wide Load, Remote Control, Electric, Heated
DR4 Mirror, O/S LH and RH, Remote Control, Electric, Heated, Light Sensitive, Power Folding, Color
DT3 Rear Box Compartment, Stowage
DT4 Ashtray, Cigarette Lighter
DUF Equipment, Duffle Bag and Daypack
D07 Console Front Compartment, Floor, Custom
D31 Mirror I/S R/V Tilt (Duplicate with D36)
D55 Console Front Compartment, Floor
D99 Body Provisions for Special Two Tone Paint
EN4 Cover, Rear Compartment Hard, Rear Compartment, Cargo
EVA Test DVT, EVAP Emission Requirement
E37 Pickup Box, Inner DK Composite
E52 Body Equipment One Piece Lift Gate With Lift Glass
E95 Cover, Rear Compartment Tonneau, Rear Compartment
FF4 Arm, Left Torsion Bar Spring Adjustment ©
FF5 Arm, Right Torsion Bar Spring Adjustment (D)
FF6 Arm, Left Torsion Bar Spring Adjustment (E)
FF7 Arm, Right Torsion Bar Spring Adjustment (F)
FK2 Arm, Left Torsion Bar Spring Adjustment (A)
FK3 Arm, Right Torsion Bar Spring Adjustment (B)
FT2 Arm, Left Torsion Bar Spring Adjustment (FT2)
FT3 Arm, Right Torsion Bar Spring Adjustment (FT3)
F0F Fleet Incentive Tourism Industry Inc. DBA Budget Sales and Leasing
F60 Spring Front Heavy Duty
GND Sales Package Avalanche Ground Affects
GT4 Axle Rear 3.73 Ratio (DUP With 5 x 1)
GT5 Axle Rear 4.10 Ratio (DUP With GT8)
GU6 Axle Rear 3.42 Ratio
G63 Provisions, Luggage Carrier, Roof
G65 Level Control Manual, Self-Adjusting
G80 Axle Positraction Limited Slip
G86 Axle, Limited Slip
JAN Plant Code Janesville, WI, USA
JE1 Brake System, Europe
JF4 Power Adjustable Pedals
JH2 Brake Hyd Power, Disc/ Disc, 7,200 lb
JH6 Brake Hyd Power, 4-Wheel Disc, 9,900 lb
JL4 Control Active Brake
J81 Indicator Switch, Export
KA6 Rear Seat Heater
KC4 Heavy Duty Engine Oil Cooling
KG3 Generator 145 Amp
KNP Cooling System Trans, HD
KUP Throttle Control Electronic
K05 Heater Engine Block
K34 Cruise Control, Automatic, Electronic
K47 Air Cleaner High Capacity
K68 Generator 105 Amp
LM7 Engine Gas, 8 CYL, 5.3L, MFI, Iron, GM
LQ4 Engine Gas, 8 CYC, 6.0L, MFI, Iron, GM
LQ9 Engine Gas, 8 CYC, 6.0L, MFI, Iron, GM, HO
LR4 Engine Gas, 8 Cechy, 4.8L MFI, Iron, GM
L18 Engine Gas, 8 CYL, 8.1L, MFI
L59 Engine Flexible Fuel (Gas/Alc), 8 cyl, 5.3L, MFI, V8, GM
MN8 Transmission Auto 4-Speed, HMD, 4L80-E, Heavy Duty
MSL Plant Code, Silao, Mexico
MTF Provisions, Fire Extinguisher Mounting
MT1 Transmission 4-Speed Auto W/Elect Controls H.D. - Hydra-Matic 4L80-E
M30 Transmission Auto 4-Speed, HMD, 4L60-E, Electronic
M32 Transmission Auto 4-Speed Hydra-Matic Drive, 4L60-E Electronic, HD
NA1 Emission System GVW less than 8, 500 lb
NA4 Emission System GVW greater than 8, 500 lb
NC1 Emission System California, LEV
NF4 Emission System Clean Fuel Fleet
NF9 Emission System General Unleaded
NK5 Steering Wheel, Standard
NP5 Steering Wheel, Leather Wrapped
NP7 Steering Column, EEC Approved
NP8 New Venture Gear 246
NR3 Transfer Case - All Wheel Drive (AWD), Open Differential, Single Speed
NR4 Transfer Case - 4 Wheel Drive (4WD), Open Differential, 2 Speed
NT3 Emission System EEC 00
NT8 Emission System, Federal, Tier 2 A
NT9 Emission System Federal, Tier 2 Phase-out
NU4 Emission System, California LEV2 Plus
NW7 Traction Control - Electronic
NYS Steering Four Wheel
NZZ Skid Plate Off-Road
N12 Exhaust System Rear Exit
N30 Steering Wheel Deluxe
N88 Wheel - New - Aluminum - 17 x 7.5, Premium
N89 Wheel - New - Aluminum - 17 x 7.5, Sport
N93 Wheel - New - Aluminum - 17 x 7.5
N94 Wheel - New - Aluminum - 17 x 7.5, Chrome
PF4 Wheel - Cast - Aluminum- 16 X 7.0
PF9 Wheel - Cast - Aluminum- 16 X 7.0
PY0 Wheel - New - Aluminum - 16 X 6.5
PY2 Wheel 16 X 6.5 Chrome Appearance
P03 Wheel Cover, Var 3
P25 Wheel 17 X 7.5 Aluminum 5-Spoke Premium
P27 Wheel 17 X 7.5 Aluminum 6-Spoke Premium
P96 Equipment Mexican Modified, Mandatory Base Equipment
QAN Tire All P265/70R 17 - 113S BW R/PE ST TL AL2
QAQ Tire All P265/70R 17 - 113H BW R/PE ST TL AL2
QAS Tire All P265/70R 17 - 113S WOL R/PE ST TL AL2
QB5 Wheel 16 x 6.5, Steel
QCP Tire All P255/70R 16 - 109H BW R/PE ST TL ALS
QIW Tire All LT245/75R16E R/PE ST TL OOR BL
QIX Tire All LT265/75R16/C BW R/PE ST TL OOR 12OQ
QIZ Tire All LT245/75R16/E BW R/PE ST TL OOR 12OQ
QJM Tire All P265/70R17 - 113SWOL R/PE ST TL OOR
QJP Tire All P265/70R17 - 113S BW R/PE ST TL OOR
QLP Tire All LT2465/75R16/E BW R/PE ST TL ALS 120/116S
QMJ Tire All P265/70R16 - 111S BW R/PE ST TL AL2
QMK Tire All P265/70R16 - 111S WOL R/PE ST TL AL2
QNK Tire All P245/75R16 - 109S BW R/PE ST TL ALS
QNL Tire All P465/75R16 - 109S WOL R/PE ST TL ALS
RYJ Shade Cargo Area, Retractable
R4W Tire Brand All, Michelin
R4Y Tire Brand All, Goodyear
R5C Tire Brand All, Bridgestone
SAF Lock, Spare Tire, Hoist Shaft
SLT Equipment Chevrolet LT Sales Package
TL1 Grille Special
TRB Grille Radiator, Body Color
TRW Provisions Lamp, Roof Mounted
TR2 Lamp Turn Signal, Enlarged
TR3 Grille Radiator, Body Color w/Chrome Emblem
TR6 Headlamps Control Leveling System, Manual
T2H Ornamentation Exterior, Export Unique Requirements
T2J Ornamentation Interior, Export Unique Requirements
T62 Daytime Running Lamp System - Delete
T74 Headlamps Control Automatic, Delay
T78 Headlamps Control - Delete
T79 Rear Fog Lamp
T84 Headlamps, Right Hand Rule of the Road, E Mark
T89 Lamp, Tail and Stop, Export
T9H Provisions Lamp, Front Fog
T96 Fog Lamps - Front
UB0 Radio AM/FM Stereo, Seek/Scan, CD, Auto Tone, Data System, Clock, ETR
UB1 Radio AM/FM Stereo, Seek/Scan, Auto Reverse Music, Search Cassette, CD, Auto Tone, Data System, Clock, ETR
UC2 Speedometer Instrument, Kilometers and Miles, Kilometer Odometer, Positive Bias
UC6 Radio AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR
UD4 Alarm, Vehicle Speed, 120 K/H
UD7 Sensor Indicator Rear Parking Assist
UE1 Communication System Vehicle, G.P.S. 1
UG1 Garage Door Opened, Universal
UG2 Garage Door Opened, Universal - Delete
UJ6 Indicator, Low Tire Pressure
UK3 Control Steering Wheel, Accessory
UK6 Radio Control RR Seat And Earphone Jacks
UL2 Frequencies, European
UL4 Frequencies, South America
UL8 Frequencies, Saudi Arabian
UM7 Radio - AM/FM Stereo, Seek/Scan Clock, ETR
UM8 Radio - AM/FM Stereo, Seek/Scan CD, ETR, Navigation Clock
UQ3 Speaker System, Performance Enhanced Audio
UQ7 Speaker System Premium Performance, Enhanced Audio, Bose®
U01 Roof Marker Lamps
U1S Player Multiple Compac Disc
U19 Speedometer INST, Kilo And Miles, Kilo Odometer
U2K Digital Audio System S-Band
U34 Display Celsius Temperature
U42 Entertainment Package Rear Seat
U84 Antenna, Body Side Window, Radio
VBX Language Label Arabic
VB3 Bumper Rear Step, Chrome, Impact Strip
VB5 Bumper Front, Color
VC4 Label Price/Fuel Economy, Puerto Rico and Virgin Islands
VC5 Label Shipping, Except US, US Possessions, or Japan
VC7 Label Price/Fuel Economy, Guam
VD1 Provision Options, Europe
VFF Video Format Region 1, NTSC
VFJ Video Format Region 2, PAL
VFK Video Format Region 3, NTSC
VFM Video Format Region 4, NTSC
VFP Video Format Region 5, PAL
VGC Protector Film, Paint Etch Preventive
VG3 Bumper Front Impact Strip
VG8 Vehicle Label, Notice to Buyer
VJ3 Label, Plate ECE Approval and Vehicle Identification
VK3 License Plate, Front Mounting Package
VPH Vehicle Preparation - Overseas Delivery
VP6 Noise Control
VR4 Trailer Hitch Weight Distributing Platform
VR6 Hook, Tie-Down, Shipping
VR7 Hook, Tow, Second Rear
VT4 Bumper Front Color Keyed
VT5 Bumper Rear Color Keyed
VXS Vehicle Complete
VZ2 Calibration Speedometer A
VZ3 Label, Mercury Disposal Notification
V1K Luggage Carrier Bar, Center Cross
V20 Guard Radiator, Grille, Black
V22 Grille Radiator, Chrome
V3A Guard Radiator, Grille, Gray and Chrome
V43 Rear Bumper Step, Color
V54 Roof Luggage Carrier, Painted
V73 Vehicle Statement, USA/Canada
V76 Front Towing Hook
V78 Vehicle Statement - Delete
V87 Vehicle Statement, Gulf States Organization
V92 Trailer Provisions
V98 Factory Delivery Processing
WBH Merchandised Package, Base Decor
WV9 Merchandised Package, Value Leader
XAN Tire Front P265/70R17-113S BW R/PE ST TL AL2
XAQ Tire Front P265/70R17-113H BW R/PE ST TL AL2
XAS Tire Front P265/70R17-113S WOL R/PE ST TL AL2
XCP Tire Front P255/70R17-109H BW R/PE ST TL ALS
XGK Tire Front LT245/75R16/E BW R/PE ST TL OOR 120Q
XHH Tire Front LT245/75R16/E BW R/PE ST TL ALS 120Q
XHS Tire Front P265/75R16-114H BW R/PE ST TL AT A Temp
XJM Tire Front P265/70R17-113S WOL R/PE ST TL OOR
XJP Tire Front P265/70R17-113S BW R/PE ST TL OOR
XLP Tire Front LT245/75R16/E BW R/PE ST TL ALS 120/116S
XMJ Tire Front P265/70R16-111S BW R/PE ST TL AL2
XMK Tire Front P265/70R16-111S WOL R/PE ST TL AL2
XNK Tire Front P245/75R16-109S BW R/PE ST TL ALS
XNL Tire Front P245/75R16-109S WOL R/PE ST TL ALS
X88 Conversion Name Plate Chevrolet
YAN Tire Rear P265/70R17-113S BW R/PE ST TL AL2
YAQ Tire Rear P265/70R17-113H BW R/PE ST TL AL2
YAS Tire Rear P265/70R17-113S WOL R/PE ST TL AL2
YCP Tire Rear P255/70R16-109H BW R/PE ST TL ALS
YE9 Convenience Package Comfort and Decor Level #3
YGK Tire Rear LT245/75R16/E BW R/PE ST TL OOR 120Q
YHH Tire Rear LT245/75R16/E BW R/PE ST TL ALS 120Q
YHS Tire Rear P265/75R16-114H BW R/PE ST TL AT A Temp Rating
YJM Tire Rear P265/70R17-113S WOL R/PE ST TL OOR
YJP Tire Rear P265/70R17-113S BW R/PE ST TL OOR
YLP Tire Rear LT245/75R16/E BW R/PE ST TL ALS 120/116S
YMJ Tire Rear P265/70R16-111S BW R/PE ST TL AL2
YMK Tire Rear P265/70R16-111S WOL R/PE ST TL AL2
YNK Tire Rear P245/75R16-109S BW R/PE ST TL ALS
YNL Tire Rear P245/75R16-109S WOL R/PE ST TL ALS
Y91 Merchandised PKG Luxury Edition
Y92 Merchandised PKG Special Edition
ZCP Tire Spare P255/70R16-109H BW R/PE ST TL ALS
ZGC Tire Spare P265/75R16-114S BW R/PE ST TL AT
ZGK Tire Spare LT245/75R16/E BW R/PE ST TL 00R 120Q
ZHH Tire Spare LT245/75R16/E BW R/PE ST TL ALS 120Q
ZHS Tire Spare P265/75R16-114H BW R/PE ST TL AT A Temp Rating
ZLP Tire Spare LT245/75R16/E BW R/PE ST TL ALS 120/116S
ZMJ Tire Spare P265/70R16-111S BW R/PE ST TL AL2
ZMK Tire Spare P265/70R16-111S WOL R/PE ST TL AL2
ZM9 Sales Package Comfort & Convenience
ZNK Tire Spare P245/75R16-109S BW R/PE ST TL ALS
ZNL Tire Spare P245/75R16-109S WOL R/PE ST TL ALS
ZQ1 Chassis Package Smooth Ride
ZW7 Chassis Package Premium Smooth Ride
ZW9 Base Body or Chassis
ZY1 Color Combination, Solid
Z49 Export Canadian Modified, Mandatory Base Equipment
Z5X Mirror Provisions, Arabic Language
Z55 Chassis Package Bi-State, Real Time Damping
Z66 Appearance Package Premium Ride Suspension
Z71 Chassis Package Off Road
Z75 Conversion Name Plate Cadillac
Z82 Trailer Provisions Special Equipment, H. D.
Z85 Chassis Package Increased Capacity
Z88 Conversion Name PLT GMC
Boy, are you ever right on that one, but add the parts department in there too. Several people here have asked about a problem with their "Autoride", but I'll be darned if I could ever find Autoride in our service information.
If you want to see if you really have it or not, look for the G69. Or, go look at the right side of the rear axle, on the rear side. There should be a big box there that holds the compressor.
Anyway, I have a TSB that may help with your problem.
Subject: Level Ride Compressor Inoperative - keywords air alc control elc height inflate line moisture rear suspension water #PIT3525B - (11/28/2006)
Models: 2002-2005 Chevrolet Avalanche
2001-2005 Chevrolet Tahoe, Suburban
2001-2005 GMC Yukon, Yukon XL, Denali, Denali XL
2002-2005 Cadillac Escalade, Escalade ESV, Escalade EXT
with RPO G69
This PI is being updated to provide new compressor part number. Please discard PIT3525A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Automatic level control inoperative due to water ingestion.
Recommendation/Instructions:
A new automatic level control service compressor part number 15254590 has been released with improvements to protect against water intrusion. The service part improvements include:
• The internal vent solenoid has an improved water intrusion resistant coating.
• The plastic air intake box has been redesigned to prevent water entry into the compressor.
The new compressor is supplied with a hose that has the new air box attached. When you install the replacement compressor, it's important to install the complete compressor assembly, including the hose and air box. The air box/hose and the differential breather hose are attached at the same location to the fuel tank filler neck. The attachment of these components requires a common plastic barbed "Christmas tree" retainer.
If you receive a Warranty Parts Return Request for a compressor replaced under warranty, be sure to include the old air box and air hose with the compressor when you package them for warranty return.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Thanks for all your replys. Especially the RPO codes. I went through and sorted out the ones that are in my glove box. Here they are
AL4 Seat RR BKT
AP9 Net Convenience
AS3 Seat RR
AXP ?
FE9 ?
PCR ?
PDC ?
PDH ?
PDY ?
R94 ?
SLM ?
VP6 Noise Control
YD3 ?
YD6 ?
1SM ?
1SZ ?
521 ?
522 ?
6XL ?
63U ?
7XL ?
Im still not quite sure what all of them mean, but I do know that based on these RPO codes that I dont have autoride. This is something Ill be taking up with the dealership tomorrow. They said that if they found that it didnt have autoride on it, that they would put something comparable to it on my rig to make up for the fact that they told me wrong. What should I ask for? The sales manager said something about air shocks that I could air up on my own, but im worried that would ruin the ride. Should I try to get them to install air bags instead? Thanks again for all your help.
Here's a couple more for ya'...
FE9 Federal Emissions
PCR Sun, Sound and Entertainment Package
PDC Cargo Package
SLM STOCK ORDERS
YD3 BASE EQUIP FOR SCH GVW PLATE
YD6 REAR SPRING - BASE EQUIPMENT
1SM LT PREFERRED EQUIPMENT GROUP
1SZ PREFERRED EQUIPMENT SAVINGS
PDY SAFE AND SECURE PACKAGE
AXP MPV VIN IDENT POSITION
6XL COMP FRT LH COMPUTER SEL SUSP
7XL COMP FRT RH COMPUTER SEL SUSP
PDH DRIVER CONVENIENCE PACK
52I TAN INTERIOR TRIM
522 TAN TRIM
63U SPORT RED MET
    Patrick Fergy
    Patrick Fergy
  • Who's Online   0 Members, 0 Anonymous, 798 Guests (See full list)
