got a qeustion bout my front end
i have a 04 hd2500 duramax 65,000miles if it matters.. but my problem is my truck wonders real bad when i have to use 4wd.. its almost scary.. pretty bad i almost wanna use 2wd on bad roads cus its just to twitchy with 4wd engaged.. it just twitchs left and right bad.. any ideas??? maybe tierods??? i know last winter it was fine no problems at all.. thanx shawn
Welcome to GM-TRUCKS
If i was you i would get under there and check to see if everything is tight or take it into a good shop around your area and have it checked out ASAP :seeya:
Hey are you also on E2S and Banshee HQ ?
Later :D
yes..  on hq more the e2s thou..
Have you checked if the front diff is topped up or have you looked at anything yet...but it sounds like what mine did and it was the drivers side CV Shaft came all loose only noticed it in 4X4....check it out mabey :seeya:
no i havent had time to take a look yet.. plus its pretty bad outside.. ima try checking it out at work next week i guess.. pissing me off i got cars passing me on the highway cus its all over.. its not gonna go anywhere but the feeling is not good.. if the cv was loose wouldnt i hear some popping or something cus everything works fine 4wd and everything just feels like the front is fighting each side ..
With that kind of mileage check your idler and pitman arms for play. A known premature wear point that really shows up worse in 4wd.
DEWFPO
  • 7 months later...
    bellssn690
    bellssn690
  • Who's Online   0 Members, 0 Anonymous, 815 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
