Check oil pressure
jayrocks
I just purchased a high milage (160000) 2001 2500HD Ext Cab with a 6.0L. I know it has some problems but do not know how to diagnose all of them.
1st- Truck would not go pass 20 mph, and had a rattle at about 4000 Rpm when you would let go of gas.
Fix= Eliminated both Cats. I dont know if this was a good or bad thing but truck runs alot better.
2nd-Leaking oil from both sides of the engine underneath when under pressure. Dont know if its a seal or what but truck has a clicking sound that gets louder at times and sets off the Check oil pressure gauge. this problem is the one that worries me the most. I have not taken it any where yet but need some advice as to what might this problem be,
Thanks for any input ..........
The clicking noise that you here is most likely coming from your lifters. When you lose oil pressure your lifters tend to collapse. As for the reasons why you are losing oil presssure and your check oil pressure light comes on can be a multiple of things. First I would pull your oil sending unit and hook up a mechanical oil pressure gauge to see exactly how much oil pressure you have. I woild imagine taht it is low considering that it sounds like your lifters are chattering. I would also compare oil pressure at the oil filter, they make an adapter that goes in place of the oil filter, remove your oil filter, screw this adapter in its place hook up the mechanical gauge and see what the pressure is. If the pressure is higher there than at the sending unit I would lean towards a cam bearing problem. If they are the same it could be a multiple of other things like
a stuck open pressure relief valve on the oil pump , a bad oil pump, a leak in your oil pump pick up tube O-ring or the tolerances on your cam/main bearings are out of specifications. Since this truck has 160,000 miles on it, it is really hard to say which one is the culprit .
I have just went through this same ordeal to an extent. I had good pressure (25psi) at the oil filter adpter and the pressure was low ( 4-5 psi) at the sending unit. Come to find out that I had a spun cam bearing. I am looking at a new engine, hopefully you have better luck that me.
The chattering sound does not always occur though, I have only noticed it at some cold starts, and when I hear it The oil pressure sensor goes off. Do you still think those are symptoms of a spun cam?
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 325 Guests (See full list)
