Couple Of Minor Issues With My New 07
Well,
I've had my 07 NBS crew cab 4.8 2WD Silverado LS for a few weeks now, almost 850 miles on it and I've noticed a few issues:
1. It idles a bit rough when I first start it for the first minute or two. It's particularly noticable if I start the truck and quickly shift into reverse, the truck tends to lurch a bit due to the rough idling. Is this because the truck is still breaking in?
2. Using my air conditioner causes some weird sound to emit from behind the passenger side dash. It's hard to describe, it's almost like a high pitch knocking/rattling. I've asked a few people that have ridden in the truck and one said it was the compressor, one said it sounded like a fan. The noise comes and goes and seems more apparent when I'm idling. Anyone else hear this in their truck? Is this normal?
3. Having the air conditioner turned up halfway or more (when a ton of air is flowing) causes some strange clicking/rattling up where the dash meets the bottom of the windshield. It almost sounds like a leaf is stuck in one of the vents and it's blowing around.
4. My driver's side visor doesn't "snap back" up when you flip it back up when not in use - like the passenger side does. It just kind of hangs - limp. The dealer already said they'd try to fix and or replace the visor, but I'd have to bring the truck back in and wait for the part to be delivered.
Other than that, this truck has been impressive so far. Thanks for any input on the above.
1. Could be that it isn't broke in yet, or try a better grade/brand of fuel.
2. If the sound is from the dash, it isn't your compressor. Could be your fan barely hitting a shroud.
3. Something probably is blowing around.
4. Tell them to order the part and call you when it comes in. Absolutely NO reason for them to keep your truck for a visor.
I'd bring it in and get a loaner and tell them not to call you until EVERYTHING is fixed.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 706 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
