WHEEL PICS
4 HELO MAXX 8 CHROME WHEELS
SIZE: 20X10 BOLT PATTERN: 8X6.5
OFFSET:-12MM BACK SPACING: 5.03"
4 NITTO MUD GRAPPLERS
LT37X13.50 R20
USED WITH LESS THAN 4000 MILES. NEVER BEEN USED OFF-ROAD. WHEELS AND TIRES ARE IN PERFECT CONDITION.
ASKING $1800 OBO.
THANKS. PICS AVAIL.
WHEEL PICS
LT37X13.50 R20
ASKING $1800 OBO.
THANKS. PICS AVAIL.
good luck finding a SERIOUS buyer here!
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 585 Guests (See full list)
