Slight Vibration
buckshot
I have a 2000 2500 silverado extended cab short box 4x4 z71.
My problem is when ever I am going up a small small hill @ about 30 degrees up i get a vibration, maybe from the rear not sure though. When I top the hill it goes away. That is the only time it occurs is when I am going up a hill. any ideas?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 585 Guests (See full list)
