Windows Fogging On The Outside
98 Chevy Silverado Z71 - Tonight was out - temp outside was in the 80's and the humidity was a little on the high sode (75%). The problem I am having is the windshield keeps fogging up. You have to turn on the wipers to clear it. No one in any of the cars around me is having this problem - WHAT is wrong?
I get the same problem on my truck here in Delaware in the evenings when it's really humid and I have the AC on the windshield setting. You can either warm up the air or switch to a different settting like vent/floor etc.
The reason it happens is because you are chilling the windshield and it contacts the humid air and forms condensation like a cold can of beer on a hot summer day. Mine does it less if I have the dash vents only running. Even in that state, the windshield vents do blow some.
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
