Roof Marker Lamps
Has anyone had roof marker lamps put onto a 1500 pickup? I want to get the new LED ones put on mine? I am just wondering what it entails.
A friend of mine spent quite a bit to have them installed on his 2500 and ended up hating it.
i was thinking about doing the same thing to mine. i think it adds allot to the look of the truck... let me know when you find out!!!
steve :confused:
I haven't done it myself but I think it's relatively simple, just tedious. Remove the headliner and A-pillar covers. Mark and drill your holes for the lights (the lights may even come with a template). Run the wires to the parking light circuit. Tap into that circuit and voila. Reinstall the headliner and pillar covers. I'm hoping to do this someday to my 1500.
Reconaccessories.com has the led kits and they come with an install kit for trucks with out preinstalled lights. Every thing they have seems to be around $100 per kit.
cab lights are one of my next projects for my 1500....i definately like the older style with 5 separate lights and not the 2 sides and 3 middle markers in the same housing....not sure about the led's..but definately like the smoke lenses with amber bulbs....the smoke lenses really set the truck off depending on the paint....mine is silver birch...so i think they will look good...
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
