Nbs Max Tire Size With 2" Lift
In the process of installing rough country's 2" lift and possibly 1" taller blocks in the rear. I have read alot of the posts on this with relations to tire upsizing. I am going to install a set of bf goodrich at's. I know 285/65/18's will work but I was wondering if anyone has the 305/65/18's or similar?
"Daddy" has a 2" Leveling kit with 305/55-20 or so, which I believe is a 33" tire. I think a 33" or lower that is no wider than 12.5" should be fine given you put them on a propper sized wheel with propper backspacing.
Mine are actually 305/50R20's which equivalent to a 32" tire where the 285/65R18 is closer to 32.6". I have no rubbing at all and would think the 32.6" would fit but can't say for sure in all situations. As for the 305/65R18's, that's a 33.6" tire and would be EXTREMELY tight if they fit.
Daddy
I have the BFG All-Terrain T/A KO's size LT285/70R17 which is 32.8" and they do rub when cutting the wheel and backing up. I actually had to change mudflaps because the wheel wells on the NBS trucks are alot smaller them classic style. I am hoping that with a 2" lift they will fit better and not rub as much.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 715 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
