2004 Silverado Ac Kicks Off On Left Side
kc5gxc
Friend has 2004 Silverado. AC has control for each side of cab. The left
side and the speedometer will quit working at same time and hot air comes
out of left side vents. It's an 8 cyl, ext. cab. 42 k miles and 2wd.
Warrantee is out but still on for this problem as it has been ongoing....he
has had it back to dealer 5 times with no fix. This is an intermittant
problem. Taking it back in on Monday for the 6 time. Once it does this, it
will not resume normal operation until the truck is shut down for a few
minutes....anyone know of a fix so he can tell the dealership what to
do????????(he is a lifetime Chevy man, but fed up to put it litely)
Thanks, Pete
the 2 problems are not related... has he had the cluster replaced for the speedometer? if not, replace it... those clusters are the biggest peices of junk ever made, i replace 2-3 clusters a week for different problems... the problem with the a/c is most likely the air temp actuator for the driver side, it isnt the easiest job to replace, you have to pull the dash back to get to it, and it is on top of the hvac case... do you know what the dealer has done so far?
Last time took back....said they replaced the actuator......working rite now.....wonder why he says every time the ac messes up, the speedo goes out???? He says it does it every time.................??? thanks for the good info so far....I'm relaying this to him.
Pete
    tblt44
    tblt44
  • Who's Online   3 Members, 0 Anonymous, 610 Guests (See full list)
