'03 Silverado Service Brake Booster Message
brute_439
Hello I recently purchased a 2003 Silverado 2500HD Extended cab 4x4 with the 6.0. I had been driving it for about a month and the speedometer quit working . I took it in and they replaced the instrument cluster. I drove it home and everything worked fine for about a week until I started it one morning and it displayed the message SERVICE BRAKE BOOSTER and the message comes up every time the vehicle is started now. Theres plenty of fluid in the resivor and the truck still stops well. The pedal seems to travel just a little more if at all. If you have any suggestion or comments that would help I would greatly appreciate it.
ive seen this happen before... what happend was when the dealer replace dthe cluster, they got lazy and didnt program it because somtimes you can get away with it, so that cluster isnt set up right for your truck... so many techs were doing that, they actually came out with a bulletin... check it out
Subject: Service Brake Booster Message - keywords assist C0136 IPC pedal vacuum #PIT3568B - (07/27/2006)
The Service Brake Booster Message is used to notify the driver of a Supplemental Brake Assist (SBA) concern on vehicles equipped with rear disk brakes and a vacuum brake booster. There have been reports of the Service Brake Booster Message being displayed on vehicles which do not use the SBA system. During normal diagnostics, a DTC C0136 may be present in the IPC. This DTC will not be in eSI if working on a 2004-2006 utility vehicle, due to all utilities use a hydroboost brake systems starting in 2004. Also note that starting in 2005; the Silverado and Sierra no longer use the SBA on vehicles with rear drum brakes and vacuum brake booster. This message could be caused by the IPC not being programmed correctly. If the IPC was replaced on a previous unrelated repair and was not SPS programmed then this message will be displayed after the IPC does not receive a valid health signal from the SBA for 5 consecutive ignition cycles.
<a href="#ss2-1850972">
Recommendation/Instructions:
To correct this concern, SPS program the IPC. To check and make sure the vehicle is repaired cycle the ignition to off and run at less 5 consecutive times, delaying in each position at least 30 seconds.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,309 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
