Engine Light Is On
pastorscott
my 04 burb with 42000 miles started to miss at idle, then would clear up after you reved the engine. This went on for about a month and then the engine light came today. Yes I have added many bottles of injecto cleaner. I tried to disconnect the battery but it was still on when I restarted after reconnectin the battery. high way speed its a smooth as silk and even after a trip today it seemed to clear up at idle again. any suggestions ???
thanks
Scott
Need to pull the code and find out what is causing the problem first. Guessing what to replace at this point can be very expensive and still leave you with the problem.
On my 03 8.1 Yukon XL, I had the same thing. It happened at about 88K. Turned out when I replaced plugs/wires, it went away. Has idled smooth ever since.
:driving: You could replace all kinds of costly items to only find out all was needed was the throttle body needed cleaning.
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 291 Guests (See full list)
