2002 2500hd Cc Lb Carrier Bearing
The carrier bearing in my 2002 finally got so bad I decided to replace it. I went to advance auto parts and they had 2 in stock so I got one and removed my driveshafts and the bad bearing. It was completely shot, the rubber between the housing and the bearing was gone, it was just sorta flopping around there. After I got the old one pressed off I noticed something a little funny, the new one was way too small. It looked identical in every way ecept the I.D. for the bearing was 1.37 and the shaft is 1.575. Luckily my brother was nice enough to run me around to 4 different parts stores just to get the same info, they don't have one. I ended up buying one for a 97 K3500, it was much larger as far as being heavy duty than the one I had but the dimensions where the same and the bearing fit just nice however I had to cut the one rubber seal/flange(wasn't used anyway, maybe on a 97 it was) to keep it from rubbing the driveshaft but I would still like to try to find the one the goes on it. Has anyone else run into this problem with the long trucks? Is this a dealer only item? I would have checked the dealers but they close around here at 2pm on a saturday so I was in bad shape. I needed to make something work so thats what I did, maybe i should just leave it alone since it is so smooth now.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
