No Cat, Would The O2 Sensor Mess Up That Bad?
chris123
So the guy before me cut the catalytic converter off and moved the muffler under the cab with the end of the exust just behind the cab. I do have the 3 wire o2 sensor infront of the muffler, but there is no one wire sensor behind it. My truck does run rich, misses, and bogs down when I give it gas giving me horrible gas milage.
I know the best thing to do is rip out this mess and replace everything, but is there anything I could do to fool the truck in thinking the sensor was working correctly? Also, I've replaced the wires, cap, EGR valve, air and gas filter.
Thanks for your help,
Chris in Tampa Bay
I always thought that the rear o2 sensors were just there to measure emissions, at least thats how it is on the newer trucks. I could be wrong. Have you tried cleaning the MAF sensor?
Edit:
Did the TBI use a MAF? Seafoam might be worth a try.
Chris in Tampa Bay
It could be a bad oxygen sensor however you don't need a cat on that truck. 1996 was the first year for the OBDII and a sensor after that cat.
TBI didn't use mass air sensor. There are several things you can check including, EGR, oxygen sensors, injectors, and fuel pressure regulator. Also, check the ignition side of things such as the plugs and wires. they would be the easiest by far to check. you can ignition problems and not burning the fuel right. But back to the cat, it's good to have one but not having one will not affect the way your truck runs, if anything most people state they run much better after removing them. They also get more of a rumble out the exhaust with no cat.
Chris in Tampa Bay
Thanks Genuinefine409, I didn't think the missing cat would cause it to become worse over time. I'm going back to square one of reviewing what I got and change out the basics again, then to the injectors/pressure.
Chris in Tampa Bay
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,309 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
