Gmt900 Sierra Foglight Size.
hey guys, this is my 4TH foglight topic and hopefully last.the new piaa setup is sweet!but the custom harness will fit three different sizes.the 5164, 5161, and 5190, wich is 510 the 4 in. light.or the 5192, 5461, and 5462. wich is the 520 the 6 1/4 in. light.or the 540 wich is the 5 1/8 in. light.wich is the exact fit if not closest to the stock size? thankstodouble,
I believe the 540 is your boy. The only true way to gauge the fit would be to go measure the openings. If you check back through the original fog light upgrade thread I am pretty sure someone mentioned them being around 5 1/4 or 5 1/2 inch housings.
Daddy
Daddy
sweet daddy thanks, your always a big help.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
