99 Suburban Hard Start.
RaysZ71
Takes forever to pop, but it will start eventually. It got a new fuel pump last year.
I am thinking fuel pressure regulator?
Also if it is, how hard to change?
thanks
Regulator is inside the upper manifold attached to the injector unit. First hook up a fuel pressure tester and see if you loose pressure. The fitting is located on the fuel feed line to injector body driver's side of the dist cap. Install fuel pressure tester and crimp the return line to the tank. Turn key to on position but do not start vec. Watch fuel pressure to see if it drops down in a steady fashion. Should go to 60psi and fall from there. Some drop is normal but if the system doesn't have a leak if should stablize around 55 or 50psi. If it does drop alot there is a updated injector unit which includes the pressure regulator and bracket, because it's possible that a injector line is leaking to. Get the updated unit because the injector are far superior and will improve your fuel milage trust me. good luck
Are you talking about there is a new updated line and regulator that mounts "outside" of the plastic intake? I am guessing you still have to pull the plastic intake to retro fit the newer style correct? I have never seen one if so were do you buy these?
Thanks
Mr. Bill
Injector unit is inside the plastic intake. Part numbers are injector unit 93441235 braket 93442096 gasket set 17113206. Top secret stuff so be carefull with this info! :M16:
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,165 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
