Adjustable Pedal Fuse
Havasubum
Does anyone know if I could pull a fuse to disable the adjustable pedals on a 2008 GMC Yukon? If so do you know the location. Thanks for the help.
the question I have is why not just not use the switch?,you have made no sense,
I am installing a US Gear braking system in the Yukon so I can tow it behind my motor home. The pedals cannot be allowed to move once it's installed due to very close adjustment tolerances of the actuator cable that pulls the brake peal when the motor home brake pedal is depressed. Thanks in advance for the help
I was hoping for a cleaner way to disable, but your solution looks like the best way.
Thanks
    BigJake
    BigJake
  • Who's Online   0 Members, 0 Anonymous, 614 Guests (See full list)
