New Jounces
Timbren manufactures an interesting product. These application specific "rubber springs" basically replace your bumpstops. In the front, they replace two of the screw-in bumpstops on your lower control arm. In the back, you remove your factory bumpstop and mount these on the frame above the rear axle. You can use them in the front suspension only, rear suspension only or both. They are very simple to install and require no drilling. They do several things; 1. help keep the vehicle stable under load, 2. assist with the extra weight of bumpers, winches, snowplows, campers, etc, 3. help those of us running racing rear springs to be able to haul extra weight without sag or extra lift, and most interestingly for us off road folks, 4. act as a sort of jounce shock in rough terrain, mellowing out the big hits and keeping the vehicle more stable in rough terrain and at high speed. They are an excellent addition to your suspension and you will notice the difference.
Does any one know where I could get some new jounces for the front of my 2001 GMC 3500 2WD??? GM wants $75 each and 4 weeks to get them!!!
Call a different dealer - MSRP is $23.17 each, and if they don't have them in stock, it should only take a day or two to get them from the regional warehouse. Part number: 15161761
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 703 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
