08 Suburban Center Console
I'm trying to customize my electonics stuff (ipod, mp3, DC-AC converter) and would like to run a couple of extra wires into the center console on my 08 Suburban. I know the trim ring around the nav screen/AC controls/push buttons is pressed on with clips and not too difficult to get off. I thought this would be the same but after some gentle but firm tugs, I couldn't get it to budge. Can anyone tell me if it's pressed on or screwed on or glued on? This would make access to the interior MUCH easier!
Also, do you know how the console is mounted to the truck? I'm trying to gain easy access to the interior to run the wires, then put everything back.
Thanks.
From the rear (closest to lid), use a tiny screwdriver or plastic trim tool to gently pop up one of the rear corners. Once you have it popped up, gently work your way around the bezel until all of the clips are released. I believe there are 4 to 6 clips, the same type holding on the trim around your radio. Don't try to pry up from the front, however, as there are two tabs at the very front that secure under the front of the console.
I pulled mine a few nights ago just to see what was in there, and I'm gonna tell ya, there is not much room to work once it's out.
Acutally on mine, i opened both lids and grabbed the middle piece and the clips will pop out. Then get the back up and pull out away from the radio. I had to get into it to wire for a amp i added.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 408 Guests (See full list)
