Cooper Zeon Ltz Or Nitto?
Not sure what happened to my other post on this topic?? d**n computer glitch :smoker: Anyways, I have cooper ATR 275-55-20 And I would like to go a little bigger in the sidewall department to fill in my fender wells a little more.
I want to keep about the same width wich is 12.69 but would like a 33" diam. tire, currently they are 32" I like the zeon coopers but can't find any deatiled specs on them, and they cost about $100 less than the nitto terra grapplers, LT 305-55-20.
Good question.
Is the cooper rated the same for weight capacity? If weight capacity is not a big issue check out Nitto's passenger tires which are about $100 less than the LTs. Probably better MPGs too, if that is a concern.
I have the Cooper LTZ 275/60/20 tires which are Cheap at Discount Tire thru ebay. $185 vs $230 for Nitto.
Like the look/ride/etc but my buddy has the Nitto's in 18'' and in -30 degree weather he has better grip on the hard pack snow or ice...
Is your truck stock height? Any rubbing issues? I am interested in these tires as well. In either the 275/55/20 305/50/20 (same height just wider) or the 275/60/20 (if they will fit without rubbing).
I have the 2'' lift and no rubbing
Without a lift they work with the right flaps and a rubber mallet at the rear of the fender where they roll in
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 356 Guests (See full list)
