04 Sierra Inst Cluster Malfunction
JMH0112
My 04 Sierra inst cluster quits working at times. Cold seems not to be a factor. Works OK at 4 degrees F, seems to not work in 20's or 30,s. At times will resume working after a short period, longer at other times. When not working, driving over rough roads doesnt bring it back up. Hasnt quit while driving,just when it sits unused for a time,say overnight. Anyone else have a similar problem? Any service bulletins from GM? Thanks
I need to know what the Last 8 digits of your VIN is and the mileage. You may be covered under a warranty for the cluster
Miles are 55866. Last 8 of VIN are 4E223446. Thanks
Good new is it is covered by factory for 7 years or 70,000 miles
Document ID# 2037454
2004 Chevrolet Chevy K Silverado - 4WD
Subject: Special Coverage Adjustment-Instrument Panel Cluster Gauge Needle Functions #07187A - (11/08/2007)
Models: 2003-2004 CADILLAC ESCALADE, ESCALADE ESV, ESCALADE EXT
2003-2004 CHEVROLET AVALANCHE, SILVERADO, SUBURBAN, TAHOE
2003-2004 GMC SIERRA, YUKON, YUKON XL
THE SERVICE PROCEDURE IN THIS BULLETIN HAS BEEN REVISED. IN A SMALL NUMBER OF VEHICLES, THE GAUGE SWEEP TEST MAY NOT ALWAYS CONFIRM THE CONDITION. PLEASE REVIEW THE SERVICE PROCEDURE IMMEDIATELY.
DUE TO PART AVAILABILITY, THIS SPECIAL COVERAGE IS BEING ADMINISTERED IN PHASES. YOU WILL BE NOTIFIED AS EACH ADDITIONAL PHASE IS RELEASED.
CUSTOMERS ARE BEING INSTRUCTED TO CONTACT THE DEALERSHIP TO ARRANGE AN APPOINTMENT IF THEY BELIEVE THEIR VEHICLE HAS THIS CONDITION. THE CUSTOMER IS BEING ASKED TO PROVIDE THE VIN SO THE IPC CAN BE ORDERED IN ADVANCE OF THE SCHEDULED APPOINTMENT. THIS WILL ELIMINATE THE NEED TO KEEP THE VEHICLE OVERNIGHT. DEALERS ARE TO OBTAIN THE VEHICLE MILEAGE WHEN SCHEDULING A SERVICE APPOINTMENT. THE VEHICLE MILEAGE WILL BE REQUIRED WHEN PLACING AN ORDER FOR THE IPC.
Condition
Some customers of 2003-2004 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles have reported that one or more of the instrument panel (IP) cluster gauges stick, flutter, or become inoperative. This may cause inaccurate readings, including the speedometer and fuel gauge.
This special coverage covers the condition described above for a period of 7 years or 70,000 miles (110,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
Dealers are to replace the instrument panel cluster after the condition has been verified. The repairs will be made at no charge to the customer.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after September 28, 2007 are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to September 28, 2007, must be submitted to the Service Contract provider.
Vehicles Involved
Involved are certain 2003-2004 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles built within the following VIN breakpoints:
2004 GMC Sierra 41100001 - 41435571
2004 GMC Sierra 4E100002 - 4E403758 your vin 4E223446
2004 GMC Sierra 4F100005 - 4F269047
2004 GMC Sierra 4Z100001 - 4Z900747
  • 1 month later...
O great have a 140,000km my just stop working today, everything with the needles stop working but the lights are fine
Would this be the same problem?
  • 3 weeks later...
I'm seeing a similar thing on my '03 2500 HD Silverado X-Cab 8.1 with Allison.
Sometimes when I start the truck all the gauges with needles do not move at all. They are seem stuck at the bottom. Usually if I restart the truck a few times the gauges start working again.
Can you run my VIN and see if you find anything? The truck has 56K on it. Last eight of the VIN are: 3E121959.
Thank you
Thank you
Well your truck is covered under the special policy (any 03-04 truck is) but your VIN shows a warranty block due to a Salvage Title eff 01/01/05 - i dont think any dealer is going to cover any warranty issues on your truck as GM probably wont pay them back. Your probably going to have to buy the new cluster and pay to have it programmed. Sorry.
its probably the same problem, since your close in miles to the policy coverage you can probably call GM customer asst and tell them you where having the problem off and on for a while but just didnt know it was covered under warranty and they might cover it under warranty.
Dam that sucks. Is there a reference number or something on this special policy? I'm call my dealer and see what they say.
  • 3 months later...
My 2004 Silverado 1500 is having the same problem. I'll drive down the road and the needle will slowly fall to 0 and my speed hasn't changed.
Can you run my VIN and see if you find anything? The truck has 68776 on it and I would like to do something fast. Last eight of the VIN are: 41324396
Thank you
:M16:
Called GM and they tell me that my 2004 Silverado is not covered by this . They say that my VIN number doesn't fall into the numbers that are covered. ???????????????? I am having the same erratic behavior as the other trucks in this year. One day it will work and the next it says I am going 15 when I am going 70. Why is my truck not included????
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,266 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
