4x4 Problem
SilveradoWV
Recently bought a 2004 GMC Envoy with 60,000 miles, vehicle looks and runs excellent, other than the 4 wheel drive. Noticed not long after we bought it, the 4 wheel drive didnt work. The lights all work on the switch and everything but the front wheels just wont pull. Took it back to the dealer and they kept it for days because they couldnt find anything wrong with it, but agreed the front wheels werent pulling, although it seems to act like it is in 4 wheel drive by the way it feels like its geared lower. They reprogrammed the computer and that didnt work. Checked the switch and the actuator and that wasnt the problem either. They said when it was up in the air the front wheels would pull but when on the ground they wouldnt, so they tore into the transfer case. The service manager said the clutches were slipping so they adjusted them and its fixed. Well it was fixed for a few weeks but now its the same problem again. The service dept is pretty shady, so I dont really trust them. Any thoughts or other things to check???
THANKS!!!
Just to add to the situation, I just went out this evening and the 4 wheel drive just worked, but it definitely wasnt working this morning. That really makes things more confusing.... :)
Not that I'm sure I can help but to start checking is that in auto 4wd 4hi or 4lo?
hope you can trust myself and Mike who are GM techs,any ways ,as a tranny ,driveline guy,I can tell you I cannot see how they "adjusted the clutch ",so I don't get it,I had the same thing on an envoy up north and could turn the frt driveshaft when in 4wd ,found the clutch pack was pooped ,so read back the bill to us to see just what the tech wrote,time paid ,if on the receipt
Well I didnt get a bill or anything the first time because we discoverred the problem not long after we purchased it. I figured we would have to pay this time since it has been about a month since the last repair. Once in the shop you could put it in 4x4 with the vehicle in the air and the front wheels would pull. however you could hold the fron tires with your hands and they would no longer pull. They said the problem was the encoder motor and that they replaced it...The 4 wheel drive does work now, hopefully that was the problem???
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,273 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
