2000 Suburban Auto Leveling Questions
flamedsierra
I have a 2000 Suburban, 1500, 4wd with 132k miles on it. The rear shocks are leaking and the compressor kicks on all the time and it is really annoying, and I also need to fix this before I start towing. I plan on towing my show truck, an 03 GMC Sierra on a 22" car hauler trailer, to the shows and all, so I want everything to be safe. I've priced the shocks and they are just under $800 for aftermarket replacement shocks from NAPA. I've just replaced all the tires, all new brakes, including both front rotors, done a full service job on the burban, so I dont have much left for the shocks. Can I just remove the Auto Leveling system completely and get some good shocks for the front and rear? If so, what shocks are recommended? Will I need to swap out the coil springs for some heavier duty shocks? Thanks for any help.
Have you isolated the leak are you sure it's the shocks?
I've used soapy water and sprayed around the compressor, all the fittings that I could find, over the air lines that I could see and the only leaks that I could find are right around the rear shocks where it looks like a clamp or boot towards the middle of them. Its a really small leak on each side which leaves me thinking that there is a leak else where. The compressor kicks on every 5-10 minutes. The suburban doesnt really seem like its sagging or leaning to one side. The only time it sags is if a trailer is hooked up to it, and then you can see the rear of the suburban lift up and then it'll slowly leak off. Both sides are about the same though, I dont notice any difference from the left side to the right side. Is there a check valve anywhere that could possibly be bad? Is there anything else that I can check? It has 132k miles so the shocks definately have some wear and I'd really like to just do away with the auto leveling system and get some regular shocks, I just dont know which shocks and the local parts stores cant seem to help me any with what shocks would work. They just want to sell me the over priced factory replacement shocks.
Well I towed an S10 about 100 miles yesterday with the Suburban. The air shocks in the back leak so the compressor ran constantly pumping them up. The compressor is now shot, so I'm taking off this auto leveling stuff. I'm not spending that much on all of this stuff when I plan on getting rid of the suburban this fall. What shocks is recommened and is there a stiffer coil spring I can get for the back?
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,171 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
