F/s: Warn H2 Light Bar W/warn Sdb-160's
I recently traded my H2 but decided to keep the lighting system. Now I don't need it so it's time to go.
The light bar is Warn # 68499 and mounts to the factory grill guard with no modifications.
http://www.warn.com/truck/mounting-systems...r_hummer2.shtml
The inside lights are Warn SDB-160HB dual beam, switchable high/low, driving lights.
http://www.warn.com/truck/lights/sdb160.shtml
The outside lights are Warn SDB-160HBE dual beam, switchable high/low, fog lights.
http://www.warn.com/truck/lights/sdb-160hbe.shtml
I also have the Warn harnesses with switches and relays linked and wrapped for a quick install using the included Blue Sea fuse panel. The fuse panel can be mounted right by the battery with the 8ga hot lead directly connect. The harness is routed through the front bulkhead and is hidden behind the grill. The only modification to the vehicle would be a small hole in the firewall to get the switch leads through.
The harness also includes a relay and wiring for an aftermarket horn system. (Necessary in Miami.)
This was a great setup for me, it just doesn't go good with the Denali. It was on my H2 for about 18 months and cost me about $800 for everything. If interested PM me and we can work something out. My eBay feedback is a perfect 100% for over 100 transactions.
    CaptainDad
    CaptainDad
  • Who's Online   0 Members, 0 Anonymous, 503 Guests (See full list)
