A/c Repair Help Needed
69ARROWHEAD
I have a 1996 Chevy Tahoe with 5.7L 2wd. Lately I have noticed the A/C not cooling as it should. I have noticed an accumilation of refrigerant oil at the suction line directly above the egr valve. It appears to be right where the transition from rubber to hard line crimp is. The truck has very low miles (45,000) and well cared for(by me). The comressor seems to be cycling as it should. I did top off the refrigerant last summer and was ice cold until now.
I want to replace the complete suction/discharge A/C line assembly as well as the filter drier as the system will be open. The auto parts store indicates there is also an orafice tube. Where is this located on my truck?
Any hints tips or tricks to taking on a project like this would be greatly appreciated.
BTW my truck does not have rear A/C.
I can't help you on the location of the orafice, other than to tell you I couldn't find it last fall. However, the hoses, compressor and drier are easy and quick to replace. Since you're not replacing the compressor, they only thing you need to worry about is how much oil to replace. The drier will have some oil, along with the hoses.
You will have to have the system recharged, including vaccumed. I paid my normal mechanic $40 (if i remember correctly) to vaccum and recharge mine (plus the freon). He told me how much oil to add (although I also replaced the compressor). He is a Lexus/Toyota guy and also didn't know where the orafice was. I looked in my two books and couldn't find it. I looked in the hose connection areas around the drier/compressor and couldn't find it.
It should take you less than an hour to replace the hoses and drier.
There is a solenoid on the side of the drier that cost about $10. I recommend replacing that at the same time.
Hope this helps.
Im not totally sure where the orifice is located, but I know it splits the High side from the low side so Check the freon line that leaves the condenser( Radiator area). its a round metal fitting maybe clamped inline on the hose near the accumulator.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,366 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
