Which Comes First, Cai Or Corsa Sport Exhaust
As I am the type of guy to appreciate the little changes, should I go Corsa Sport first, or CAI then Corsa?
Please vote only if you have both.
Doesn't matter if your going to have both eventually. Though, I would imagine that if there will be a long time difference with the two ( like you get intake done now, then exhaust 6 months later ) going with the CAI first may be hard for the OEM exhaust to filter. But then again OEM exhaust on these trucks flows very well.
Ok I thought about it enough, personally, I would take the good sound now, & helpful performance later, get the Corsa exhaust, then CAI.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 715 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
