Need A New Power Steering Pump...will This Work?
My power steering pump doesnt work when at idle, turns like no power steering, and have to rev it up to make it start to work. Its fine on fluids, so the pump must be weak/bad. I was surfin on ebay, and came across this whole assembly.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...A:IT&ih=005
Everything looks the same, and is off a whats called a Gen 3 vortec. On their other items they seemed to put 2004 gm 5.3s in their jeeps and this was probably their part. Would this assembly work, it sure looks exactly the same, but i didnt know if they changed their setup from 1999-2007 anytime.
It ends in 4 days so Id like to know as soon as possible if you guys think it will work.
It should be the same. I don't think the PS Pump changed over that time period. Only thing is that I am personally leery of buying stuff like that off e-bay. Good Luck.
I never had any issues, with 772 transactions, I had 2 problems, which is nothing to speak of. I have a belt squeak too and I never replaced my idler pulley yet, and it comes with one. Also its all new take off stuff so its new basically anyways.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 857 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
