Help With Dual Climate Control
dacjac
on my 04 sierra crew cab this is an intermitten problem with the dual climate control with the ac on the drivers side will switch to heat after about 5 min and the passengers side stays nice and cold if I shut the truck off and restart if it will blow out cold air again and it's ok.
You more than likely need a new actuator. Also, there is a calibration update to help with the actuator limits. That is the easy actuator to change. It is on the bottom of the case.
thanks for the reply 'BlueGorilla' is the actuator expensive
  • 3 weeks later...
