Steering Column Slants To The Left
Raven
I noticed that the steering wheel's right side (when looking at it while in the driver's seat) is closer to me than the left. Closer inspection revealed that the gap between the steering column and the instrument panel is much narrower on the left side than on the right and that the entire column is biased to the left side of the truck. This makes for a weird feel when you turn the truck, especially when crossing hands over in hard turns.
I pointed this out to my service adviser and he said they would look at it closer when I take it in for the first oil change.
Anyone else have this problem? Is there any sort of bulletin out on this issue? Lastly, is it a big deal to fix and get the steering wheel more properly in line with my body?
I had the same problem on my '03 Silverado. I also had a problem with the driver's side door being too close to the dash when shut. It caused the speaker grill on the bose speaker to rub the dash and created a pile of plastic dust on the carpet below it (cheese grater effect). I reported that problem and the dealer's solution was to order a brand new grill and then put a dent in it so that the dash wouldn't hit it any longer. After that, I decided to live with the steering wheel being slightly cocked to the left (and gap at the dash), since it didn't affect driving and I was too scared to see how they would "fix" it.
Wow, Todd. You've got a FIRST CLASS dealer there!!
GIT-ER-DUNN!! :crazy:
Pretty much all the dealer service depts in my area are like that. I won't give out any names, in case someone from there is lurking on this board (which could make life even more difficult for future warranty visits). The 1 and only time I took my '07 in, they attempted to fix the rear seat. It was loose and you could hear it rattle on every little bump in the road. Now, after the "fix", it rattles twice as much. When it gets bad enough to motivate me to fix it, I'll pull the seat and figure out how to fix it correctly. I think I've done more warranty work on my GM vehicles than GM over the past 15 years. What's even worse are the service advisers I've dealt with. They think they know everything about your truck and that you know nothing. I'm sure its not like that everywhere, but I seem to be a magnet for the crappy ones. I took a TSB in once to show them what was really wrong with my truck (after they tried twice to fix the rear window in my '03 extended cab by replacing it), and it really pissed them off. However, my truck got fixed right that time!
What you guys have mentioned is one of my biggest fears - having the dealer 'fix' something only to make it OR SOMETHING ELSE worse in doing so.
It's still danged annoying but I can live with it if I have to. I just am wondering if this is more rampant than we know...
The problem is that alot of dealer service departments ('advisers' as well as techs) don't read all the TSB's that come out. I work for a supplier of GM parts, and we recently made a change to a major steering component to eliminate a warranty problem. Unfortunately, I know we're going to get all kinds of returns because the current 'fix' they have is to grease it. The change we made will actually cause a failure if they add grease to it. GM's solution? Issue a TSB. I only hope they read it.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,326 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
