4x4 Coil Over Conversion Lift Kit!
That's pretty cool if you're into the prerunner thing.
The 1999 to 2006 Chevy 4x4 front end kit offers you a wider track width of 4" pr side with option of coilover, bypass, and bumpstop pr wheel and an estimated wheel travel of 15" with 4 wheel drive and 37" tires (fiberglass fenders recommended). The upper arms are billet aluminum made from 6160. These custom machined arms use 3/4" heims on the inner pivot points witch are locked in with a custom machined plates that fill in the stock oval alignment holes to keep the alignment from being knocked out. The lower arms are made from 1/8" 4130 plate, power coated and run a 1" uniball in place of the stock ball joint. This kit comes with just about everything you need to install and is fairly easy for some one with some fabrication and welding skills.
  • 1 year later...
