04 Chev 4x4 With A "service 4wd " Being Displayed
First of all i must say this site is great!(i'm new here)
This morning my truck started in auto 4wd,the display is is saying service 4wd and it won't come out of auto back to 2wd (it's push button 4wd) anyone know where i can start ? this thing is acting like it is 4wd going around corners
There's been a lot of problems with faulty switches on the 99-06 trucks. Many have been replaced. Do a search. You can order the switch at a reasonable price. I had the switch problem on my 04 and the dealer did some sort of reprogram. So that may be an option too. If the truck is in 4x4 you need to get it out. Others might have a better suggestion, but a battery disconnect might reset the switch and allow it to put the truck back in 2wd?
i'll try the battery thing first(to get it out) i'm kind of wondering how it went in by itself to begin with ..... i couldn't find a search option on here ,i'll look again Thanks!!!
I had an issue on my wife's '99 Jimmy where it would randomly say 'service 4x4' and wouldn't change from the drive mode it was in. After checking all fluids, sensors, etc. I determined it was the switch, and for less than $50 (bought it at CarQuest, everyone else said it was dealer only) the problem has been gone for almost a year.
YEAH I'VE SEEN A LOT OF ENCODER RING SENSORS IN WHICH CASE YOU WOULD JUST NEED TO BUY A SENSOR A GASKET AND FOUR NEW BOLTS, THERE IS ALSO A PROGRAM FOR THAT ISSUE WHICH GETS RID OF THE PLAY THAT CAUSES IT THE FAILURE TO BEGIN WITH
MY TRUCK DID THE SAME THING TO ME....IF YOU JUST REPLACE THE PUSH BUTTON SWITCH IT WILL BE OK...THEY CRACK ON THE BACK SIDE OF THEM AND IT MAKES THEM GO BAD.....I BOUGHT MINE OFF EBAY FOR 40 DOLLARS. IF YOU PULL YOU DASH BOARD OF AND WIGGLE THE SWITCH...AND HIT THE 2WD BUTTON IT WILL COME OUT OF "AUTO" AND YOU WILL BE OK.....BUT YOU STILL NEED A NEW SWITCH...
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 1,009 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
