Vibration Noise
I remember that post about the vibration noise from the tranny, like between shifts. Most people said they had theirs reprogramed but lost MPG. Just wondering what the noise actually is and if it can do damage!
WV,
How's southern WV?  I had this issue, if you're referring to the "growl" when the trany shifts into lockup then OD @ around 40 mph.  They flashed a new PCM code that doesn't allow the OD shift till around 53 mph (when you're not "on it").  It worked, and honestly, I don't see where guys were losing mileage - mine has been EPA all the time 15/18.  Last summer I drove thru Okla, TX and NM 80mph+ loaded for camping, w/ topper and air on about 1/2 time, and got 18.9!!!
I can see a little drop, bu no way this caused 3-4 mph as a few were saying!
Southern WV is Hot and Humid as always. Thats the noise I was referring to, might have to check into that. Just wondering if its doing any damage the more I put it off??? Well thanks for the help!
In Beckley, the nights always cooled off though, no matter how hot and humid it got during the day.
I never got the impression that it did any damage, just an annoyance mostly.  I'm guessing that it's some sort of low-RPM harmonic among drivetrain components.  ???  ???
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 382 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
