Trying To Remove The Radiator Fan ...
Do you need the special tool to remove the fan assembly? Or can you a a large adjustable wrench and break her free??
Is the fan assembly attached directly to the water pump? After the fan is removed, then the pulley can be removed? Thanks!
On my truck it was attached directly to the water pump. A large adjustable wrench will work if you can hold the pulley still (a large strap-wrench might work). I've heard that if you put a punch bit in an air hammer and hit the corner of the nut that holds on the fan, it will break it loose.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 353 Guests (See full list)
