Windshield Replacement
I need to have the windshield in my 2008 Sierra Denali replaced. The truck is equipped with the rain sense II system and I'd like it to still work after I get a new windshield. Is there a different windshield because of this feature or are they all the same?
I'd have to double check but I think the windshields are the same,You are going to need a new lens however.
From the service manual....
Windshield Replacement--Replace Lens Only
If it is necessary to replace the vehicle's windshield, a new moisture sensitive lens, P/N 15829099, will need to be ordered with the new windshield. Replace the lens from the old sensor with the new moisture sensitive lens. Then remove the plastic protective covering from the new lens and install the sensor to the new windshield. Refer to Windshield Outside Moisture Sensor Lens Replacement in SI.
*EDIT* I double checked,The windshield IS different with the "CE1" option.
OK,I checked....There IS a different windshield if you have the "CE1" rain-sense option.
There is a note to order a new lens as I mentioned earlier.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 585 Guests (See full list)
