so the guy before me some how had the starter hooked up so that it ran non-stop all the time so im guessin that why it burnt out. so now that i have a new starter i put it in i run my own Ignition switch wire and i had to run it all the way up to a push button but with my lack of knowledge im guessin i didnt have something ran right. so is there anyway someone can explain to me how to run a brand spankin new ignition switch and what do i connect it to. also does the starter have to be grounded. and its a 1982 jimmy 454 with a 400 turbo do u think i need to shim the starter
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 554 Guests (See full list)
