89 Jimmy No Power
hddave2
hello..i got a 89 gmc jimmy with the 4.3 4x4 and it seems to bog down alot..the best way to describe it is when im going down the road say 55mph i have to really put my foot in it to maintain that speed..i live in the county so i drive alot on paved curvy roads up and down small hills and if im going up hill the truck just bogs down and i have to hit the gas at liest halfway to the floor to maintain a serton speed.. the truck dont miss or hesitate or backfire through the tbi ,it just bogs down alot..now some days are better than others..i have changes plugs wires, replaced all vac. lines. sprayed carb cleaner around tbi to check for vac leaks..i changed the tbi to intake gasket just to rule that out. even changed the air filter.. i have not had a check engine light come on since i've owned the truck. the truck idles good and it starts up good so im at a loss to what could cause this..i even took the truck to a tranny shop to let a tech drive it and tell me if the trans was slipping, he said it shifted fine and smooth.. i know i smell gas fumes when i have to push the peddle harder to keep up to speed..could some help me out with this....thanks guys
Unplug the timing sensor, It should be a tan or brown wire from the distributor, may be in the glove box. Get a timing light and set to 0 deg off the #1 plug. Also check what the advanced is pulling.
Is there slack in the timing chain?
i agree with the timin chain thang i might would also check the cat for hair balls :thumbs:
yea i might have to get a shop to check the timing and chain..believe it or not but no cat. converter on the truck..
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,132 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
