Engine Chirp / Squeak When Hot...no One Can Figure Out
swhsah
I have a 2002 chevy silverado 2500hd with a 6.0L engine and 220k miles. When the engine is cold at start up All is OK. When the engine reaches operating temperatures I get a engine chirp. The chirp increases in frequency with engine rpm and is no longer audible above 1800 rpm.
I removed the front a/c belt and the main serpentine belt to eliminate them as a source. I then unbolted the torque convertor in addition to isolate the area of the noise. The noise is definately in the engine. To me the noise seems to be coming from the center of the oil pan as is louder when listening from under the truck than from the top of the engine.
I thought of a bad rod bearing but the noise is a definate chirp and not a knock. I then decided to pull the oil pan and inspect the rod bearings anyway. All looked OK, so I installed a new set of rod bearings .001 undersize due to the mileage of the truck. I then filled the crankcase with straight 30W oil and test ran. I had no change and the squeak comes back when hot.
I then had a tech look at it and he was convinced noise was in the valve train with the pushrods being worn into the rocker arms. I installed a new set of rocker arms and pushrods. Again no change. the squeak still comes back when hot.
I am starting to think the cam may have spun a bearing causing the squeak / chirp. I am a Caterillar certified technician and not being able to find this is driving me nuts. Any help would be greatly appriciated.
Thanks
Scott :crackup:
Thanks
Scott :crackup:
weird.... piston sleeve damage? not much else is moving.. pistons, rings, camshaft, lifters,... did you check them? basically all thats left lol
I have not torn the engine down to far to find out as I need the truck to get back an forth to work. The chirp is rpm dependent and has a metalic sheet metal sort of sound. I did check the flywheel when I had the torque converter disconnected. From underneath the truck it sounds like it is toward the center of the oil pad as it is louder when listened to from under the truck. You can see about 70% of the cam with the pan down but to be honest I did not look very hard to see if a cam bearing had walked out. I may just be reserved to drive it untill it quits and buy a bone yard replacement engine as I see them for around $1300 and up. Then I could tear it down and find the source.
Thanks
Scott
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,230 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
