Darlington qualifying results
MountaineerTom
From thatsracin.com
Unofficial results from Friday's qualifying for the Southern 500 at Darlington Raceway with position, car number, driver, car make and speed:
1. (97) Kurt Busch, Ford, 168.048.
2. (24) Jeff Gordon, Chevrolet, 167.916.
3. (12) Jeremy Mayfield, Ford, 167.911.
4. (2) Rusty Wallace, Ford, 167.882.
5. (29) Kevin Harvick, Chevrolet, 167.871.
6. (43) John Andretti, Dodge, 167.493.
7. (32) Ricky Craven, Ford, 167.396.
8. (36) Ken Schrader, Pontiac, 167.254.
9. (9) Bill Elliott, Dodge, 167.231.
10. (18) Bobby Labonte, Pontiac, 167.208.
11. (25) Jerry Nadeau, Chevrolet, 167.027.
12. (40) Sterling Marlin, Dodge, 166.993.
13. (6) Mark Martin, Ford, 166.947.
14. (93) Dave Blaney, Dodge, 166.862.
15. (26) Jimmy Spencer, Ford, 166.800.
16. (77) Robert Pressley, Ford, 166.670.
17. (10) Johnny Benson, Pontiac, 166.625.
18. (8) Dale Earnhardt Jr., Chevrolet, 166.394.
19. (5) Terry Labonte, Chevrolet, 166.366.
20. (21) Elliott Sadler, Ford, 166.354.
21. (55) Bobby Hamilton, Chevrolet, 166.343.
22. (92) Stacy Compton, Dodge, 166.017.
23. (99) Jeff Burton, Ford, 166.012.
24. (33) Joe Nemechek, Chevrolet, 165.984.
25. (15) Michael Waltrip, Chevrolet, 165.956.
26. (28) Ricky Rudd, Ford, 165.917.
27. (88) Dale Jarrett, Ford, 165.905.
28. (17) Matt Kenseth, Ford, 165.777.
29. Kevin Lepage, Chevrolet, 165.749.
30. Casey Atwood, Dodge, 165.726.
31. Todd Bodine, Ford, 165.687.
32. Brett Bodine, Ford, 165.615.
33. Tony Stewart, Pontiac, 165.604.
34. Steve Park, Chevrolet, 165.553.
35. Mike Skinner, Chevrolet, 165.537.
36. Hut Stricklin, Ford, 165.109.
37. Ward Burton, Dodge, provisional.
38. Jason Leffler, Dodge, provisional.
39. Mike Wallace, Ford, provisional.
40. Ron Hornaday, Pontiac, provisional.
41. Buckshot Jones, Dodge, provisional.
42. Kyle Petty, Dodge, provisional.
43. Rick Mast, Pontiac, provisional.
Other speeds
(14) Ron Hornaday, Pontiac, 164.854; (7) Mike Wallace, Ford, 164.490; (45) Kyle Petty, Dodge, 164.347; (96) Andy Houston, Ford, 164.336; (01) Jason Leffler, Dodge, 164.155; (71) Dave Marcis, Chevrolet, 163.811; (44) Buckshot Jones, Dodge, 163.713; (27) Rick Mast, Pontiac, 161.976; (22) Ward Burton, Dodge, no speed.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
