Tpms On Dic
sleblanc63
My window sticker says my truck has TPMS but I cannot see it on the DIC.
Do you have the DIC controls on the left side of the dash or only the push button in the gauge cluster? If you only have the gauge cluster version you will not see the pressures, only if/when the pressures drop low enough to set off a warning will you see anything. There is a simple $100 fix to this problem though. Check the link to the DIC upgrade in my signature.
Oh, and welcome! :throwup:
Damn W/T's :throwup:
Yes, you'll have do the DIC upgrade then. Search on here and you'll find your info.
+1!! and welcome to GMT!
Right on. Gotta have the DIC upgrade... Know if the 09 is similar to the 07?
Should be exactly the same. Remove the panel on the left hand side of the dash and look for the wire clipped into the back of the panel that you'll need to plug into the DIC controls when you order the new panel and switches. If the cable is there, you'll be set!
Good luck!
First mod on order! Ordered the DIC upgrade from the GM accessories store.
https://gmaccessoriesstore.com/index.php
Was $102 + tax at the dealer (not in stock) ... cost me $85 plus shipping from the GM store. Hope it's as easy as everyone says. Already sweating the yanking a part of dash off my brand freaking new truck. Did you slip a screw driver under one corner and pry to start or what? Is the removing replacing the knobs idiot proof? Pop off pop on? This site rocks. Thanks for the info!
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 525 Guests (See full list)
