So I'm picking up the rims in about 2-3 hours and the guy said they fit an 05 Escalade for sure...my question is will they fit the newer Escalades too? Thanks in advance.
They should, yes.
They should, yes.
Thanks a lot man!
  • 3 weeks later...
:fume::lol:
:fume::lol:
+ :D:D
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 524 Guests (See full list)
