1989 Gmc G2500 Vandura 5.7 V8
I Have a 1989 GMC G2500 Vandura 5.7 V8, The van cranks but
will not start. This is a conversion van so the manuals
I purchased in 1989 do not help much since electrical and
computer has been switched around by the conversion company,,,
Headlights, horn, tail lamps, ECM-B, and crank circuit have NO POWER.
... Fuses OK,,,,
Has anyone else had this problem or any ideas on a fix??? Greatly
appreciate any advice,,, Chris
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 715 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
