2006 Tahoe Z71 2wd Hydroboost
I have a 206 tahoe z71 2wd that i think the hydroboost is leakig fluid but the brake reservoir is full and the p/s fluid is fine.first noticed drips on the garage floor and popped the hood and everything underneath the booster and master cylinder is dirty and oily.any ideas on how to check other than clean it off and wach for the leak?thanks
My Guess For you if its still under warranty take it in. Or Clean the Master Cylinder and the Brake Booster and palce something Under it Like a paper towel and let it sit for a day so it can leak agine, Also Clean the floor it might be something else.
no warranty left 53k do you it would be worth a try to see if gm would help?,thanks
They will charge you. They might put a color die in the oil And follow it that way. But it will cost you.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
