All Activity
- Today
Bridgestone vs Goodyear tires?
Vu1can replied to Philipgonzales3's topic in 2019-2026 Silverado 1500 & Sierra 1500
Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone. I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them. -
davester started following Broke Down on the Mountain
davester replied to Gangly's topic in 2019-2026 Silverado 1500 & Sierra 1500
maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc... -
Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case. Once I get it 100% done I will post here result....
What did you do to your "other" car (aka musclecar) today
PunchT37 replied to RyanbabZ71's topic in The Off-Topic Bar
I used to work on those 4.6, 2V engines. They are tough. -
Jsdirt replied to RyanbabZ71's topic in The Off-Topic Bar
Nice! I wish I had something to put them on. Someday when the engine craps out in our '86 Grand Marquis I guess. My truck is diesel, so won't need one for that. The Merc is at 315k miles right now with zero signs of slowing down! I'm more of an Edelbrock guy, though. I like super-simple. -
Whit.the.COB joined the community
That's a beautiful thing! The one I'm converting now is my winter beater. Only has 114 HP at the crank stock, LOL. 2.3L 4-banger. Pathetic in the power department, but it gets me to work all winter. -
Carbs rule. -
2010 Avalanche 5.3 not running correctly after engine swap.
Jsdirt replied to contrabombarde's topic in Ask A GM Technician
Well that's progress! Nice. Man! I hate all this modern crap! Nothing is simple anymore! Since you've tried known-good MAFs, I'm betting on something being missing on one of the 5 wires. Disregard the IAT sensor wires, and focus just on the MAF wiring. Power, ground, signal return. Something isn't right on one of them. I'm doing a carb conversion on a 1994 vehicle right now. Everything is simple, and just works! If something doesn't work, you MAKE it work! Glad to be out of the industry, that's for sure - I don't miss the computer crap! -
Just an update, I bought a one VIN subscription to sps2, installed the PCM from the 2007 donor vehicle and programmed it. It started right up, and seems to run more normally now (It doesn't die as soon as you start it, it just starts and runs every time, no more misfires too), however, the MAF is still showing the same strange readings.
Hey everyone, For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV. The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers. A few details: 50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
Glava2876 replied to RyanbabZ71's topic in The Off-Topic Bar
Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb". ONE MB??? That's Windows 95 ******, lol!! -
KARNUT replied to RyanbabZ71's topic in The Off-Topic Bar
I get the same results with pictures. Then I figure it out. Then I forget. Screw it. -
I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads? I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem! I'd post pics of what I'm working on ... but I CAN'T! Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago. Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle! Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season. Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol. Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS Seems like that site went back to dial-up internet! Maybe they'll fix that some day ... -
Atlas replied to RyanbabZ71's topic in The Off-Topic Bar
Triumph makes me think of cars not bikes. Especially with model names like the TR7, that was a Triumph car model too. Peak TR for me was the TR250. You could retain the post-war roadster looks, with an optional surrey hard top, but with an inline 6 engine instead of the TR4's anemic 4-cylinder, but still have a 4 speed, optional overdrive. I know almost nothing about Triumph bikes, except that they exist. Good looking bikes though. I don't know if I could just have one vehicle. The Silverado does it all except for fitting anywhere. But it leaves a void in real driving enjoyment, unless driving an extremely large sofa is your thing. What did I do to my 'other' (muslce car - which one!?) vehicle lately. I took my '23 SS for a drive. It's only got 1600 miles. I keep reminding myself I shouldn't be so precious about this car. It likes to be driven. Needs to be driven. Life is short and if I don't enjoy it, someone else will. The other half calls it "the garage ornament". -
Hey everyone, Thought we’d share our 40" SLIM Light Bar setup for the 2022+ Chevrolet Silverado 1500 for anyone looking at behind-the-grille lighting options. The 40" bar sits behind the lower factory grille, so it stays pretty well hidden when it’s off. The mounting position is also adjustable, which helps with getting the bar positioned properly depending on the grille. A few details on the setup: 40" SLIM LED light bar Fits 2022–2026 Silverado 1500 Spot + flood beam pattern White, amber, or white with amber DRL backglow Adjustable mounting position No cutting or drilling required Doesn't interfere with the active grille shutters Vehicle-specific mounting brackets It’s a straightforward option for anyone who wants the coverage of a 40" bar but prefers to keep the front of the truck relatively stock-looking. Curious what the Silverado owners here prefer — hidden behind-the-grille lighting or an exposed bumper-mounted setup?
- m&r lightbars
- off road lights
(and 3 more)
Tagged with:
Grumpy Bear replied to RyanbabZ71's topic in The Off-Topic Bar
Yes. Absolutely. That doesn't mean I don't like and enjoy a variety of machines. I went for a time with no other vehicle than a 1976 Triumph TR7-V Tiger. Loved that bike and rode it 365 in any and all weather. I did not feel deprived of anything. -
No Software Updates - Old Build
DaleB replied to DaleB's topic in Troubleshooting, Warranty & Recalls
Thanks, all. It sounds like keeping the software "as is" is the best course of action. -
https://en.wikipedia.org/wiki/Overengineering Excerpt from the above link: (BTW the above is a 90 second read) [Quote] A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5] [End Quote} By Engineering's own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends. On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground. I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot. Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA. It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot. What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA. There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time. I guess that's what happens over 186K miles of use :) Big Kudos to O'Reilly's for letting me work on the truck in their parking lot. However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :) Getting towed off the mountain. UCA Ball Joint Socket Trashed CV Suspension disconnected and UCA and CV Removed New UCA and CV installed with the suspension buttoned up.
My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
