Does Traverse's Steerling Wheel Also Fits Silverado ?
No it won't, they look the same but the hole is a different size. Only Sierra, silverado, tahoe, yukon, suburban are alike
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,642 Guests (See full list)
    • I have 2 choices.
