FS: K&N FIPK 99+
OK, I'm selling the FIPK. It has only been on the truck two months, and the filter 1 month. I was using the filter off the AirRaid. This FIPK has all the parts, manuals, charger kit(new), and box. I'm asking $210 and I pay shipping up to $15 or so. Make me a good offer and I may come down. I have been seeing them on E-bay for 220 and up + shipping.
BTW, it fits a 99+GM truck 4.8/5.3
  • 1 month later...
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
