Fan Speed Issues (2005 Silverado)
I have been researching some of the issues with the Fan Speed Issues and the fan blower resister malfunctioning. But that was if Speed 5 (high) was working and nothing else; then it was the resister.
However, my problem is that Speeds 1-2-3 work and Speed 4-5 are not working. What is my problem?
Back when I bought the truck in April/May none of the Fan Speeds worked and the dealer fixed it before I took delivery of the truck.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
